heystak:Octopo:
The 2400 also has pre-outs for connecting a stereo amp should you feel the need later on.
I've read a similar suggestion on another post - I assume it allows the front speakers to receive output from the stereo amp and so provide a better sound? Could you explain how this is connected up? 5.1 (inc fronts) connected to the AV amp and fronts only connected to the stereo amp? That cant be right can it?
This allows the use of stereo kit with the same front left and right speakers from the 5.1 set up, and is connected like this:
Front pre-out sockets are connected to a spare input, e.g aux, on a stereo amp. Front left and right speakers are only connected to the stereo amp. All other speakers connected to AV amp as normal. When listening to stereo music, say from a CD player connected to the stereo amp, the AV kit can be turned off and you get the best possible stereo sound from your hi-fi kit. For movies, you have the AV kit on as well as the stereo kit, as the AV kit processes the sound for the front left and right channels and outputs it to the speakers via the stereo amp.
The AV kit has to be re-calibrated once the stereo kit has been introduced to the 5.1 set-up, with the stereo amp volume set to a level easy to replicate, e.g 12 o' clock. For surround listening, always have stereo amp on, with correct input selected (e.g aux) and volume at the level chosen when calibration was done (e.g. 12 o' clock). The AV kit is then used as normal, all processing done via AV amp and volume controlled from AV amp.
