Hello all members,
I'm here to ask you expertise and tips about some doubts I'm getting with my 1st home cinema setup...
So, I have a Yamaha RX-V459 AV receiver (europe model) with the following audio specs:
• Minimum RMS Output Power for Front, Center, Surround, Surround back
20 Hz to 20 kHz, 0.06% THD, 8 Ω ...................................... 90 W
• Maximum Power (EIAJ)
[Asia, China, Korea and General models]
1 kHz, 10% THD, 8 Ω ........................................................ 130 W
• Dynamic Power (IHF)
8/6/4/2 Ω ........................................................ 120/155/190/235 W
• Maximum Output Power [Europe model]
1 kHz, 0.7% THD, 4 Ω ....................................................... 140 W
• IEC Output Power [Europe and Asia models]
1 kHz, 0.06% THD, 8 Ω ..................................................... 100 W
• Damping Factor (IHF)
20 Hz to 20 kHz, 8 Ω ................................................. 120 or more
To connect on it I have also a Yamaham 6.1CH SPEAKER PACKAGE NX-230P (front and back speakers) + NX-C230 (center speaker) + YST-SW005 (subwoofer) with these specs:
NX-230P, NX-C230
Type ......... Full range acoustic-suspension speaker system
Magnetic shielding type
Driver ........................ 5 cm (2”) full range cone speaker x 2
Nominal Input Power ................................................. 30W
Maximum Input Power ............................................. 100W
Impedance ..................................................................... 6Ω
Frequency Response
<NX-230P>........................................... 100 Hz to 30 kHz
<NX-C230> ............................................ 75 Hz to 30 kHz
Sensitivity ................................................... 86 dB/2.83V/m
Subwoofer YST-SW005
Type ............... Advanced Yamaha Active Servo Technology
Driver ....................................... 16 cm (6-1/2”) cone woofer
Amplifier Output
EU models ..................................................... 50 W/5Ω
Frequency Response .............................. 30 Hz to 200 Hz
Power Supply
U.K. and Europe models ........................ AC 230V, 50 Hz
I'm thinking to replace my center speaker NX-C230 with a Tannoy Mercury mC B/EYE or with a Yamaha NS-C105. What I could find about their specs are:
Tannoy Mercury mC B/EYE:
Frequency Response: 70Hz - 20kHz
Sensitivity: 90dB
Nominal Impedance: 8 Ohms
Power Handling: 140 Watts (RMS)
Drivers: 1 x 25mm soft dome | 2 x 102mm paper cone
Yamaha NS-C105:
10 cm cone woofer X 2 2.5 cm dome tweeter Input terminal : Screw type Nominal Impedance: 6 ohms
Frequency Response: 65 Hz - 20 KHz (-10dB) Resonance Frequency: 150Hz
Nominal Input Power: 50W
Music Input Power: 200W
Sensitivity: 90 dB/w/m
Crossover Frequency Tweeter (Low Cut): 6KHz, 6 dB/oct.
My question is if, in fact any of these two exchanges worth it and if there isn't any problem I get a speaker with more Watt (140W) that the RMS value of my receiver (90W) in the case of the Tannoy speaker
It is true that the receiver should have allways at least 50% more Watt per channel than the respective speakers?
Thanks in advance for all the tips and opinions.
Cheers!
NX-230P, NX-C230
Frequency Response
Subwoofer YST-SW005
Amplifier Output
Power Supply
Sensitivity: 90dB
Yamaha NS-C105:
Cheers!
