Ceiling speaker mount
Greggerly
11
Hi guys
Looking for universal ceiling brackets to mount my speakers. Yes, I know they should be ear level but my office is a tiny room and the only reasonable way to mount them is from the ceiling angled down. I've found a few brackets but they usually require drilling into speakers which I'm not fond of.
Do you know of any cradle tyle mounts that I can use?
Speakers to mount are not the largest ones - Q Acoustic Concept 20. Circa 6kg each.
thanks for any pointers
Deleted member 108165
Maybe a pair of your wife's tights or stockings would do the job. :) Place speakers in leg, knot the open end and hang from a hook in the ceiling, angle as required ;) Fishnet would be my preference.
I'm sure someone with more sensible ideas will be along soon.
