can u help.....
Tony_R
17
Do you want closed or open headphones?
I see somebody has recommended the Grado SR60's but they will 'leak' a lot of sound.
So if there are others in the room trying to listen to / watch something else they will be disturbed.
For closed back I would recommend something from the Beyer range.
Tony.
You can pick up Grado SR-80s new on ebay for less than £90 buy it now with free shipping. Even 125s can be had to under £100 from time to time.
