- Aug 10, 2019
- 2,556
- 5
- 0
My system consists of NAD 370 / 270 amplification, Mission M35 loudspeakers, Sony XDP300 cd player (I know a bit dated, but still very servicable). The system is used in bi - amp / bi - wire configuration. The 370 is wired to the HF terminals of the speakers,and the 270 is wired to the LF terminals. The speaker cable is QED Mk 2 high performance bi - wire cable. All connections are of the correct polarity. The speakers have been positioned at various distances from the wall, and various "toe in" angles have been tried. (The room is approx. 5m x 5m).
The problem with this system is lack of bass, unless the system is played at high volume, which of course it will play very loud with clean undistorted playback. I am wondering if the amplifiers are capable of delivering bass at lower, comfortable listening levels, or should I consider adding a sub - woofer, if this is to be the case, is there any advice on how this might be connected.
Geoff Turner, Chichester, West Sussex.
