Bit of a strange one this.
I recently bought some Kef iQ5se's to go with my 640aV2 and 640cV2, however, when getting to about 11o'clock on the dial, the CAP5 protection cuts in and I have to turn the amp off and on again to reset.
The CAP5 gives 3 flashes, so its not an overheating issue, alas the amp isn't overly hot when it cuts out.
The amp is on its own shelf and is well ventilated. All cabling has been checked and all connections are tidy and tight. I'm using decent cable too, QED Silver Anniversary.
I previously ran some B&W 601s2 and they have similar spec, 8ohm, 88dB sensivity etc, but the amp never cut out, it would be rediculously loud by 11:30 on the dial, and would go higher if needed.
I'm not trying to create a disco type environment or anything here, but occassionally I like the music pretty loud. I just need a whisker more volume and I'll be overjoyed, I'm not expecting to be able to crank it to 12 o'clock even, it really is just a "bit" more that I'm after. At present normal listening is about 10o'clock on the dial, but as the night goes on it inevitably gets nudged up...
There is no clipping (dial doesn't ****** back at all either), no distortion and the speakers sound amazing. The system sounds superb and I'm very happy, its just this annoying max volume issue.
Cambridge Audio tech support tell me that although the iQ5se are rated at 8ohm, they specify 3.2ohm min, and the CAT5 cuts in at/below 4ohm, and therefore my speakers aren't compatible!
Most speaker manufacturers don't specify a minimum impedence for their speakers, so I'm not really sure what to do now to be honest.
Any ideas people? Thanks in advance/anticipation!
Tom.
Tom.
