Question Cables for KEF LS50
Cyborg56
Hello everyone!
I have recently purchased KEF LS50's associated with my Marantz PM6005. I need to change the cable because the old ones are too short (I've changed apartments). I now need 3m.
What do you think of these
Do you think I should take a more extensive section? 4mm for example ?
Also, I thought I read that the LS50 doesn't accept banana plugs. Is it true ?
Thanks in advance
nopiano
For a 3 metre length, then electrically speaking the resistance of 2.5mm section is no problem. You might prefer to over specify with 4mm as the usual audiophile idea is ”bigger is better”. I can’t comment on the brand, as I would personally choose a manufacturer like Van Damme if you can buy that in France.
The LS50 takes banana plugs, and you can buy pre-terminated cables from a dealer or eBay.
ASK THE COMMUNITY
