Cable - Need a best buy please?
Always cut the red wire!
21
Hi all,
Do you know where to find the cheapest deals for approx 30-40 metres of either:
Chord Company Carnival Silver Screen (found £5.20/m)
OR
QED Silver Anniversary XT (found £3.50/m)
Also, Is the QED Micro just as good as the QED Silver Anniv’ XT?
Thanks in advance.
Micro is not the same as the XT cable, there is far greater sheilding on the XT. You will probably find the best deal in store and you will more than likely get the cable cut and properly terminated as well.
