- Oct 16, 2008
- 106
- 0
- 0
I bought 0,5 meters of Chord Chameleon Silver to connect my DacMagic to my Cambridge 740A.
I had read that the cable neeeded burn in (because the silver sounds harsh just out of the box).
I was sceptic!
I had also read that alot of people who don't believe that cables make a difference, have stated that your ears get used to the harsh sound and therefore you fool yourself into believeing that the cable has been burned in after a while.
So I plugged the cables in. Listened for half an hour. Was shocked at the harsheness the cable produced. Guitars almost hurt my ears, and the soundstage was strangely light and fluffy. Not good!
So, I decided not to listen to the cable anymore for 4 days. To rule out that my ears would get used to the awful sound.
I turned off the amp, and set Metallica's Death Magnetic to loop for 4 days which ought to be sufficient for the burn in.
Needles to say, I was pretty excited when I turned on the amp again to listen if anything had changed.
It did! Away was the harsheness, the soundstage was wide and open, and the increase in details was significant compared to my old Tara Labs cables.
So if you ask me, burn in is not cable voodoo. It worked for my Chameleon, and I would guess, also for other cables.
Tha' tha' thats all folks...
I was sceptic!
