- May 23, 2016
- 7
- 0
- 0
shadders said:Hi,
To keep it simple, do the following.
Take out all input cables to the amplifier.
Plug in the suspected cable - seems to be the red cable of the stereo cable pair. Does it buzz
Take this cable out of that input, both wires (red and white), and plug into another input. Does it buzz?
If it buzzes on one and not the other, it is the input, and the amplifier is at fault.
If it buzzes on all inputs, try a different cable.
If the different cable buzzes, try another source - you seem to have a cd player so this would be the best one to use, not the PC.
If a different cable buzzes and a different source buzzes, it seems to confirm that it is the amp.
If you need to keep costs down, then for the same price a second hand amplifier is a good option. Try and get a well known make such as Denon, or Marantz - I state these brands as I checked a second hand Web site in the UK, and this seemed to be in your price range.
Regards,
Shadders.
I plugged the amplifier into my phone and the speakers don't buzz now, how can I stop the buzzing when it's in my PC?
BigH said:Have you got any headphones?
Yeah, but they don't fit in the headphone output from my amplifier.
