Buying a new system any advice
I have just joined the forum and am buying a new system after reading the reviews.
Unfortunately the other items im buying i cant find on the site could you please have a look and direct me in the right way if there are changes.
Marantz Pm 6002 Amp £230
Dali Lektor 1 £250
Soundstyle Z1 speaker stands or Soundstyle ST122 £99.95 0r £102.50
Denon ASD-11R Ipod dock £69.95
Monitor audio pureflow Bi wire speaker cable £ 10 per metre
Appreciate your help
Many thanks
Brian
Hi Brian and welcome 🙂
What would be handy to know is what music do you listen to? Also; have you considered/demo'd other separates as well or have you got your heart set on this system?
Hi Dan
I listen to everything but not a lot of dance or rap.
I have listened to the amp .I am looking for a value system which will bring me a bit off fun.
The system i choose is just for an ipod.
With regards to the above, you don't need them, Atacama Nexus would be absolutely fine as they are a very sturdy and highly thought of speaker stand anyway.
Totally agree with HiFi Nerwbie - You dont need to spend that amount on stgands for a budget system. Take a look at the Atacama Nexus 5/6 stands and also consider filling them with atabites to dampen them a well. Much better for bass response.
Also; with regards to amps; have you demo'd the NAD C315 integrated? IMO its hell; of a lot better than the Marantz with a much fuller soundstage and would match the Dali's much better also.
