Budget MC or Mid-Range MM?
If I want to upgrade cartridges on a Project Debut III, is it worth going for a budget Ortofon MC worth £95 or an mid-range MM cartridge by Ortofon for around £85?
at 95 e or grado black.no need to spend that much money.give it 20 to 30 hours to bed in and you will be very happy.if you must have an mc you can get the denon dl110 for around £70.00
I will take on board your idea. I've only been using it for a couple of hours...may be the problem!
Thanks and Merry xmas!
if i'm not mistaken the project either comes with the ortofon om5 or 10 and or the at 95e. if it's the om you can upgrade the stylus to the 20,30 or 40,they are all very good.if it's the at stick with it i have one on my spare deck and am considering putting on my linn lp12,it's that good.
