boston accoustic xs or cambridge audio minx mini10 for rear speakers
Hi
im after a set of small rear speakers that are wall mountable to be used as rears in my bedroom home cinema setup. now as theyre being wallmounted right behind my bed dont want something too big
ive been looking at both the boston xs and cambridge minx mini10 speakers and am unsure of which ones to get. has anyone had any experience of either systems and if so which would you recommend or are there any others i should be looking at
the speakers are gonna be used along side tonnoy f4 & fc speakers, ae sub and will be powered by a denon 2807
thanks
f1only
278
A pair of Tannoy F1's would make sense, although not as small as the speakers you are suggesting, would match the rest of your speakers for better integration. These can be had for £70 or less new.
Regards...
hi
where the speakers are going there isnt enough space for the f1. i used to use a pair of morduant short 903i but due to changing the room layout these no longer fit so has to be a small satalite speaker
