Better alternative for Definitive Technology BP-6Bs
cano22
Hi everyone,
I am planning to replace my Definitive Technology BP-6Bs, but I am confused what to buy to improve. I am totally pleased with its bass sounds, however I need sounds of trebles such as guitars, saxophones and vocal to be better and detailed.
I am using Rotel RSX-1055 as an amplifier, in a 30m2 room.
What speakers can you suggest that can create real difference without reduce anything?
Floorstand or bookshelf (if it is sufficient) , i will look for used ones and my budget is around 400-500$
I don't have a sub, I just want a pair of speakers. Thank you for your help.
Unfortunately, it is over my budget.
Bookshelf speakers like Rega rs1, rega rsx, b&w 601, b&w cm1 ,dali oberon 1,
can they fill up my room of 30m2?
