Best speakers for 7 watt t-amp?
chunky70
32
Hi all.
I'm in the process of putting together a second system for my spare room (4m by 4m) consisting of:
Marantz cd 5004
Topping TP20
I have a pair of mission m33i's which i've tried with this combo but although they are 8 ohms and 90db sensitivity they just sound aneamic especially with large scale orchestral or heavy rock.
So bearing in mind the t-amp outputs 7 watts into 8 ohm what sort of speakers am i to look at? I'm thinking high sensitivity bookshelf would be the best bet.
£300 is my budget.
Thanks all.
Crossie
58
94 dB sensitivity - Klipsch KG 3.5 horn Speakers NOS (new old stock) £325
Might be worth a look:
http://www.ebay.co.uk/itm/Klipsch-KG-3-5-horn-Speakers-NOS-new-old-stock-COLLECTION-ONLY-/251509029806?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item3a8f1b3bae
Richard Allen
12
+1
Al ears
+1
I'd hardly call that bookshelf - read the OP's thread again :)
To the OP. As you might have gathered high-efficiency bookshelf speakers are in short supply.
These however should suit your requirements should you have the space for them.
Richard Allen
12
+1
Hence +1
chunky70
32
Yes i'm finding it hard to locate high efficiancy bookshelves at a reasonable price. Those klipsch are front ported so i might get away with those!
I'm presuming small speakers are hard to make with high sensitivity.
I'm loath to go down the AB amp route now, my t-amp sounds so detailed and with a wide soundstage i've fallen in love with the little thing!
chunky70
32
Thanks chebby.
Those RB-61's look ideal, guess i'll have to stretch the budget a bit. Now how do i justify that to the other half! :?
