Best speaker cable to run under carpet?
PaulShaw01
18
Hi there
I'm just moving into a new flat and putting in new carpets. The opportunity is there to run speaker cables under the carpet and keep my wife happy.
Can you recommend a good cable that (ideally flat) that will go well with Dali Ikon 1 surround speakers, and a Denon 2310 surround amplifier?
Paul
aliEnRIK
92
In my experience, flat cables tend to sound pretty flat too (as in bass light)
I'd also consider the risk that if in the future somone manages to puncture and link the positive and negative then you could blow your amplifier
ESP2009
177
What are you thinking of in terms of budget? How far do the cables need to run?
I found the unjacketed version of Chord Odyssey 2 very unobtrusive under the carpet, but the much cheaper Van Damme cable that aliEnRIK recommends isn't far behind, both in terms of sonic ability and carpet-friendliness.
aliEnRIK
92
Thaiman:Ortophon spk 300
Interesting choice (if spelled wrong). Have you tried said cables?
They dont appear to be on their own site and the 200 and 400s certainly dont look like theyd look and feel nice under a carpet
What IS of interest to me is the composition. OCC copper which ive been looking for ages for (Although im not happy theyve silver plated it)
aliEnRIK
92
scene:ESP2009:
PaulShaw01@hotmail.com:I need about 35mtrs
Yike!!!!
Is that in one run, or total - i.e. about 18m to each rear speaker?
If the latter, then I'd recommend some QED Incognito One, which can be had on 20m spools from Superfi for £11.95 a spool. QED Incognito One 20m
You recommend it because youve tried it?
scene
aliEnRIK:scene:ESP2009:
Yike!!!!
I needed 2x15m runs for my rear speakers, and on recommendation from Pindi (IIRC) I purchased 2x20m reels of QED One from Superfi. Seems to do the business, 99.999% OFC, no silver, very flexible. Small prize if you can find it on the QED website directly (you can do it from google). Very happy with it, particularly at the price
Thaiman
360
aliEnRIK:
spelled wrong? You could say that on every posts I made
and yes, I am using the very ortofon in my pub and restaurant. I would never recomended anything on any forum unless I have heard or use them myself. All I can say is they are very durable, many people have walk over them not to mention tables and chairs! no problem so far. The sound is a lot better than the standard 50p per metre jobby we use to have but I suppose my customers wouldn't care any way. I bought them from Henley design who also have plenty of goodies for sale (now and again) for very reasonable price.
Now O.P is telling us that he will need 35 metre (and for a surrounds channels) so my advise is to get the cheapest rolls of cables you can find!
aliEnRIK
92
Cheers Thaiman
I would certainly expect OCC copper to outperform cheapie cables
I dont wish to pry, im just intrigued - may I ask which pub/restaurant you own?
Thaiman
360
aliEnRIK:
Cheers Thaiman
The Crawfish Inn in North Norfolk (away from any civilisation...nr Holt). My chef is pretty good (according to my wife's waist line)
f1only
278
I use Profigold Hi Performance Flatflex Speaker Cable sits, nice & flat, did the job for me under my carpet, even though its probably not the best cable in the world.
