Best Fiio amp/dac under €150 For Ananda Stealth?
demosthenes
Hi all.
I am looking for an amp/dac to run my new Hifiman Ananda Stealth from my phone/tablet. Where I live, it’s hard to find anyone selling them online other than Fiio.
The max I could spend is €150 and I don’t really care whether it’s a Bluetooth model, a dongle or a desktop amp. Just wondering what the best bang for my buck in terms of amplification and Dac would be from fiio
Rodolfo
347
179
1,070
iFi and Micca also make some good ones under 150 euros. Some are more portable and spec'd than others. Hope you have found or can find and test some of these with your fancy Anandas.
Aug 7, 2024
With a budget of 150€ and the need to power Hifiman Ananda Stealth headphones, I recommend you consider the Fiio K3 DAC/Amp.
