If your components allow, XLR. Optical suffers from jitter at its connections and coax suffers from electrical interference. XLR is a studio standard balanced connection which is designed to cancel interference, and because shielding is not necessary much cheaper too. Other than that coax is best over short distances, optical over long - though it's dependent on your electronics whether you'll be able to hear the difference.
