Just wanted to know what has the best dac denon 1930 dvd or yam 763av, at present i play cds in the denon using digital connection to the yam, just wanted to ask if i would be better connecting with analog and useing the denon dac.
T
the record spot
Yup, that's about it mate; set up, plug in, open yer lugs!
Gerrardasnails
295
nick46:Just wanted to know what has the best dac denon 1930 dvd or yam 763av, at present i play cds in the denon using digital connection to the yam, just wanted to ask if i would be better connecting with analog and useing the denon dac.
I would go for the Denon but I agree with the others...
John Duncan
And with my experience of Yamahas I'd use its DAC, but it's a straightforward compare - the Denon will probably allow you to have both the analogue outputs and the digital playing at the same time, and swap between the two inputs on the amp...
