BDP 320 not playing 24bit PCM
Sliced Bread
500
87
18,970
I have just noticed that when I play an uncompressed 24bit sound track (such as no country for old men) my bluray player (Pioneer bdp320) is stating that the audio is 16 bit when I press the display button.
The bluray player is hdmi 1.3, as is the hdmi lead (Van Den Hul The Flat) and my amplifier (Onkyo 905). Does anyone have idea what might be causing this?
The_Lhc
1,176
Stupid question time, you are actually selecting the HD audio soundtrack rather than the vanilla DD/DTS?
Told you it was a stupid question...
Sliced Bread
500
87
18,970
That's ok...it's a fair question
Yes I am selecting the HD soundtrack.
Sliced Bread
500
87
18,970
Thanks the_lhc! If this works when I try it tonight you will get a gold star
There are no obvious options in the Pioneers menu to do this as far as I can tell from the manual - although they must be there. They have an HDMI audio option for Auto or PCM, so I guess Auto is bit-stream. I will have a play tonight
Sliced Bread
500
87
18,970
I may have some problems with this, according to this quote from a review in another website:
"Overall, I found the set-up menus confusing. I'm used to having the ability to change from bitstream out to PCM out or to enable or disable Secondary Audio output in the menus. On the Pioneer many of the audio options are grayed out, depending on how you're connecting and how the player has decided to set your optimal settings. "
There is also this, but still no mention of uncompressed tracks.
"Apparently to get the full quality Dolby TrueHD or DTS-HD Master Audio lossless bitstream to your compatible receiver or preamp/processor select "Dolby Digital 2" and "DTS 2," otherwise the player will mix in BD Secondary Audio and may output the lossy core track (DTS) and companion track (Dolby Digital) instead of the lossless track, even over the HDMI outputs."
Sliced Bread
500
87
18,970
Thanks...I have just spoken to Pioneer. As my amplifier displays TRUE-HD and DTS_MA when films with these formats are played it looks like the player is already set to Auto (they confirmed that this is Pioneer speak for bitstream).
The support guy was very helpful although a bit stumped as to why 24 bit uncompressed soundtracks are then read as 16 bit. He is going to talk to the engineers and call me back. I'll let you know what they say.
The_Lhc
1,176
Sliced Bread:Thanks...I have just spoken to Pioneer. As my amplifier displays TRUE-HD and DTS_MA when films with these formats are played it looks like the player is already set to Auto (they confirmed that this is Pioneer speak for bitstream).
Err? I thought you said earlier the amp displayed Multi-CH?
Sliced Bread
500
87
18,970
the_lhc:Sliced Bread:
Thanks...I have just spoken to Pioneer. As my amplifier displays TRUE-HD and DTS_MA when films with these formats are played it looks like the player is already set to Auto (they confirmed that this is Pioneer speak for bitstream).Err? I thought you said earlier the amp displayed Multi-CH?
Sorry..I should have clarified. The amp displays Multi-CH when receiving an uncompressed track. True-HD and DTS-MA are both working fine and decoded by the amp.
