BBC HD Test Card
Can anybody tell me when BBC HD broadcasts their HD test card. An article from Andrew Quested on the BBC Internet Blog shows how this can be used to calibrate a TV, but I'm not sure when its televised. I have SKY HD (and do not have access to freeview, if that makes a difference).
It is on the BBC HD Preview, here are the details:
The HD test card is just over 1 hour into the promo and the AV sync signal is 50 minutes later. To record both signals, check the time the last programme finishes and add 1 hour. So if the last programme ends at 01:30 set your PVR to record from 02:25 to 02:45 for the test card and 03:15 to 03:35 for the AV sync signal.ÿ
Thanks topbloke. I'll give it a try. I wasn't sure that this happened on SKYHD: when there is nothing in the schedule, I thought that it went to a preview mode (showing clips of other programmes). I haven't stayed up to the small hours to check this though.
