Basic Mixer
ianstewart
I have been looking for a simple mixer without success. Sometimes I need to produce electronic music at home using a computer, which is then played through active monitors via an audio interface. I also put a turntable through the monitors using a phono stage. I would like to get rid of the studio mixer, with eq and aux sends, and just plug both into a simple mixer. Two stereo inputs would be fine, or maybe three as one day I may get the cassette deck repaired; and one stereo output, preferably with xlr connectors. Does any forum member know if such a mixer exists?
Many thanks for any advice.
Gray
Have a look at the Behringer range of small mixers (and similar models from the likes of Soundcraft).
There was a time when low cost mixers guaranteed you hiss and / or hum, but times have changed.
Some of them include usb interfaces, decent mic preamps and good digital effects - for very reasonable prices.
It’s not really a Hifi ‘thing’, mixers, but a quick google of a store i have used turned up this. There are many permutations, but if you need some help I’d find a convenient music/pro shop rather than an Audio T or Sevenoaks.
Is this along the right lines, albeit no XLR output?
you are correct its not really hifi but I don't know where best to move it to so it can stay here....
ianstewart
Many thanks for your replies, I appreciate it. The reason I posted my query on a hi-fi forum is because I know that the hi-fi world does not use aux sends and rarely eq. I was thinking of the days when I had a turntable, cassette player and radio plugged into an amplifier. The reason I don't want to get a hi-fi amplifier is because my monitors are powered and hi-fi amplifiers tend to colour the sound - in a good way of course.
Thanks for the link Nopiano, that is the sort of thing I am looking for providing I can find one that is professional studio quality for the audio interface.
As suggested, I think the only solution is a pro-audio studio mixer, which will of course, have pan, aux sends, eq etc.
Al ears, mixing in the digital domain is a possibility except it means using the computer to play a vinyl record or cassette.
We live in a small flat, otherwise I would have a good sized studio and an entirely separate hi-fi set-up.
Gray
Surely the reason you don't want to get an amplifier is because you don't need one due to having one in your speakers.....and that's why you're asking about a mixer.
But anyway, I wonder why you think a good amp should colour the sound any more than a mixer (on which the eq is often used to deliberately alter sound from neutral).
