My current speakers are a pair of B&W 602 S2 I bought new years ago. It it currently set up ideally in my den of my condo on a pair of B&W stands. The rest of my system comprises of a NAD 326BEE, Rotel RCD-1072 and a Cambridge Audio DacMagic Plus with a BT-100 which I have connected to my Macbook Pro.
I would like to upgrade the speakers as they are getting tired. I am between the Monitor Audio BX2s and the 685S2. They are both well reviewed and I feel they will play low enough, just based on the specs. My current 602 S2s are are benefitting from being corner loaded at the moment, they sound the best they have every sounded. I never had the volume knob past 9 o'clock on the 326' if anyone owns one. I have no intentions of adding a subwoofer and I would prefer a front firing port so I can reduce the chances of disturbing my neighbours.
My current 602 S2s sound great, but I am curious how trickle down technology comes into play almost 20 years down the road which is why I am considering 685 S2s. I am satisfied with the low end extention of my 602 S2s right now, but I am wondering if I would get better high frequency extention and detailed midrange with a set of 685 s2 or a set of Monitor Audio BX2s. I am trying to decide between the two at the moment. I usually stream off Soundcloud and the top tracks my playlist as I type this are: Belly featuring the Weeknd with "Might Not" and Odesza's Light (with Little Dragon) and Ben Pearce's "What I Might Do". My floors are hardwood and the walls are drywall, but I have a rug on the ground.
The BX2s are less money, but I had a set of 602 S2 for nearly 20 years. I was thinking I should just go with a pair of 685 S2s to appreciate the improvements over the years, but it is more money and maybe I should try something new. Anyone out there have first hand experience with the both the BX2s and 685 S2s? Or all three?
Any input would be appreciated.
