Recently I purchased a 40W4500 and so far I'm impressed with the tv and the quality of the images. However, there is one problem which I find extremely annoying: the auto dimming feature. When playing Far Cry 2 on my Xbox 360, connected through a high quality HDMI cable, dark places/areas with low-light/shadows are very dark and without any details visible. When you approach this dark area in the game, the image becomes lighter when you're close and details become visible. Enemies from a distance are hence almost not visible when they are in the shadow, because the image is almost black. When you're inside buildings/houses and there is not a lot of light, a lot of detail is lost because of the too dark image.
I turned the advanced contrast enhancement option and the light sensor OFF, but the problem is still there. I tried both standard and cinema picture modes, adjusted the back light to higher and lower values, changed the brightness both in the tv menu and in the game menu... but without succes, the auto dimming feature is still there and it ruins my game experience. Is my set faulty, or is there a solution to this problem? How can I get rid off the auto dimming feature?
