I know this subject has been done to death but i couldn't find any ref's to my problems but ill run by you guys any how. I must done 10 Audyssey setups now and I'm starting to get frustrated now.
I'm struggling to get a good bass response from the sub its either too strong (causing the sub to bottom out) or too weak ( you can barley hear/feel it at all) and no amount of level adjustment seems to adjust it either way. Its strange its as if the sub is being eq way past the sweat spot or out of room. It not that i want loads of bass it just seems to be no happy in between
The subs gain is at the 10/11 o'clock position with the level showing at -3 on the amp
The other problem i have is that i get a sort or unbalanced front end giving the effect that its out of phase but the cable are in there corresponding red and black positions on the terminals. All the levels are set 75db using an slp and the distances seem right but the front three don't seem to mesh together
Hope some one can help
Thanks in advance
Thanks in advance
