audiolab m dac problem
musical0111
28
hi can you help i bought a second hand audiolab m dac and have a problem when
playing my blu ray audio discs in hi res 24/192 the dac wont lock on to it, and keeps cutting in and out,, i also have a problem with a clicking sound
when streaming on optical from qubuz any ideas how to correct the problems welcome i use a mac for streaming and sony bluray
for digital out to dac.
philpot1001
16
how have you connected the device? The latest M-DAC cannot deal with that resolution through USB, it needs to use coaxial / optical.......not sure about previous revs of the M-DAC and whether they have that resolution at all?
Native_bon
182
18,595
Your M-dac should play 24bit files. If it's not, then it may be a problem with cable or the file it's self. Does it do it on all files?. Usb is restricted to 24/96KHz. Optical & coaxial 24bit/192. Check output settings from your sources. Also if the problem exist from all inputs to the dac, the dac may well have a fault.
