Recently been upgrading my system to the following: -
Monitor Audio rx6 speakers
NAD 356bee amp (with copperline alpha mains lead)
Marantz cd6004 CDP (with Russ Andrews Powerkord Standard)
Chord Cobra plus 0.5m interconnect
Chord Rumour 2 speaker cable
I am very pleased with the setup, however I need to tame the stupidly over-reactive volume on my NAD amp! Low level listening is difficult and at very low volumes, there is a slight volume bias to the left channel, which clears up with more volume. However for reference, 9pm on the amp is pretty loud!! My previous and trusty NAD C340 amp seemingly had a better volume control!
Therefore I have just ordered some 'Goldenjacks' attenuators on Ebay (-6dB to start with, I know -6dB is low) to hopefully help with the volume issue.
I have also just bought some s/h Russ Andrews 'timbre' jumper leads on ebay to replace the pre-power jumpers on the back of my Nad amp.
I will of course do some experimenting, but would I be better with the attenuators between CDP and amp or connected between the pre and power section of my integrated amp? I only have the CDP connected to my amp (I regularly use an ipod which is connected digitally to the CDP).
I've heard they are usually better between the pre and power amp, rather than the CDP?
Anyone have any experience please?
Thanks very much,
Richard
Thanks very much,
Richard
