ATC SCM11 In-Wall/On-Wall
I have noticed these under the Custom Install section of an ATC Concept (i.e. HT/HC) brochure. Strangely, from the spec's, it appears that they can actually go quite
a bit deeper into the bass than their normal/standard companions.
Has anyone had any experience with these versions of the ATC SCM11 (i.e. ATC SCM11-I and/or ATC SCM11-S)? Thanks!
