Arcam Solo CD skipping
sixofnine
When I play CD-Rs on my Solo I usually get a glitch in the first few minutes, but then it plays OK. It doesn't always happen, but I have accepted that it is probably because the Solo is not designed to play CD-Rs, and it was the price I paid for playing my (legally) downloaded music. However, it occasionally does it with commercial CDs too. Is it a fault or are the transports a bit temperamental and picky about what they play?
[quote user="sixofnine"]Is it a fault or are the transports a bit temperamental and picky about what they play?[/quote]
If it play a commercial cd OK but have problem with CD-r then it must be a bit picky!
However with most of cd player now a day using PC-base cd rom as a transport I can't see why you should have a problem with Solo! Did you closed the cd properly? or try different software writing a music disc?...
