Arcam SA30 Audio Delay
Witterings
I had an audio delay using the AV Bypass for my surroud fronts but found an thread somewhere that said Dirac causes it so use direct mode and it disappears which worked and \I'm using on the PVR input.
I'd like to be able to use the digital inputs though for a multiroom streamer where again there's a delay and the devices out o sync. I've plugged it into the CD anaologue input (via an external dac) and used direct and againt it goes away and syncs but I wanted to us the onboard DAC as well as freeing up the analogue inputs.
I've tried going through the various Dirac settings, I'm guessing "No Curve" simply turns off any colouring / room compensation but it's still going via Dirac and still a delay, does anyone know if there's any way to the delay via the digital inputs?
