Eddiek said:
Ha ha ha, I'm sure you've all been waiting for the slew of follow up questions so here goes;
1 blimey, isn't it illegal for an av amp to sound this good playing my music?
2 it's telling me I'm using small fronts with auto set up (I have the as previously mentioned ae aegis evo 3 floorstanders-by the amps standards are they "small" or is it simply making a mistake?
3 How would I do as suggested make the dv79 transport only
4 I'm an Ethernet connection short of the amount of sockets I want, is there any form of spliter ect to make 4 ethernets 5?
5 Can someone call into work for me so I can stay home tomorrow playing?
Glad you are enjoying it......it's a big achievement for an AV amp to sound this good with music, and it will sound substantially better with something like the R500/R700. Coming from an AVR300, it will sound as if you've had a speaker upgrade, as the power and extension of the bass is a revelation and the sound has much more verve.
Whether a speaker is small is not decided by it's physical size but by its frequency response. Technically a speaker is only deemed as large if it's 20Hz - 20kHz.
Rick's suggestion is a good one, as I find the DV79 (which is good for a DVD player) a little lifeless and "shut in" sounding when compared to the Linn, for 2 channel - so it's worth a go. You will need to connect a digital lead from the "digital out" of the DV79 to the "digital in" section of the AVR600 (P.10 of the manual).
I've never tried doing this so let us know how it goes.
