Hi guys, I'm a newbie on the block and realising the benifits of a decent hifi set up.
Set up - I have Arcam CD37 CD player, Arcam FMJ A32 intigrated amp, Arcam Alpha 10P power amp. Monitor audio GX300 speakers.
Currently sey set up with the A32 to the speaker HF and the 10P to the LF.
Question - I wanted more power for the GX300's so should I buy another 10P and then fit the mono link on each one and use one 10P per speaker, then use the A32 as a pre-amp only?
Would this increase the power output from the 10p's (ie more than the rated 100W).
Is there a better way of doing it with the Arcam?
I was concidering buying a Arcam P38 but from what I read I probably won't gain or notice much difference over the 10P.
Any thoughts or experience out there?
Cheers,
Cheers,
