Yes you will use the AEX dac. Quality will also depend on the quality of your files. Not only can you stream from your touch but also from your PC as long as you have wifi. Rip cds as lossless and you have a better quality than if you have downsized your music to go onto your touchkrish123 said:right well i will be connecting it with standard aux rca cable, so does this mean it will use the aex DAC?
