In my bedroom so 2nd set up as wanted small, running off a quad vena.I told you
What amp?
What amp?
I might move them closer the the front of the cabinet,closet so the rear port isn't to close to the wall, 2 inches,5 cm should be possibleIn my bedroom so 2nd set up as wanted small, running off a quad vena.View attachment 1010View attachment 1011
I took the bass test again with 5 hz increments it drops a bit from 90 to 85 hz and again at 80hz than it might be a little louder at 75hz, i can hear bass all the way down to 45hz not at 40hz with the same volume.
There is alot of bass if the recording allows the speakers to play bass
