Analogue Cable Help Please
I need 6 analogue cables to connect my Sony BDPS550 Blu-Ray analogue audio feed to my analogue inputs on my Aego P5 surround amp because it doesn't have hdmi connection and after checking cables online I'm getting confused.
Can anyone advise the type of analogue cable I need and also offer a recommended 0.5m one to use at a reasonable price. Is it just simply 6 Analogue RCA Leads I need or something else.
Would appreciate any help on this
Yes, six analogue RCA leads - or three pairs, if you like.
You may find buying 1m lengths cheaper, simply because budget cables tend to come in 1m minimum, and only more expensive types in 0.5m lengths. However, I am sure you can find one of the many ebay online sellers offering 0.5m budget cables.
Thanks Andrew,
Any you you would recommend as I don't want to spend too much on them.
