nopiano said:
super said:
Naim audio service their amps and one of the main things they change are the capacitors. But if you're going to replace yours anyway within a couple of years i wouldn't bother.
I can't decide if this is just a chance to extract money from gullible customers, or if it really improves an aging amp. If the latter, why do they fit such inferior components?
There are plenty on Naim forums who testify how marvellous their amp sounded when it comes back. But my amp sounds marvellous after I've been away on holiday!
They don't usually fit inferior components per se but there is clearly a choice of vfm parts for manufacturers.
A lot has to do with how folks use the amps.
I know a guy that still uses his Olive Naims and never had anything done to them.
Having said that, a japanese made Nichicon may well be better, longer lasting than a chinese made counterpart. I wouldn't know.
Its also not always the electrolytes that most people think about (the main ones) that fail. In my CDP (cyrus) one of the small panasonic SFM which act to regulate power supply to the transport failed.
They could even have been damaged/compromised by a solder machine which has not been maintained or heated to much at point of hand soldering.
So many variables.
What is indesputable is that a well ventilated chassis and a lot of space between parts can only be a good thing. This makes Cyrus and other tightly packed products suspect in theory but there are plenty of those out there that have been going for 20+ years without problems.
I guess its a bit like going out and being run over by a bus ... or not.
A bit of luck of the draw.
Happy Easter x
