Amp recommendation under £2500
Hi rchinn
From your neighbours in Norway Hegel Music Systems new Rost amp/DAC/streamer/headphone amp is also worth a look.
An excellent match for B&W loudspeakers and thanks to Hegel's SoundEngine technology the Rost doesn't run hot.
All the best
Rick @ Musicraft
MUSICRAFT said:
Hi rchinn
All the best
Rick @ Musicraft
It has no facility for turntable as far as I an aware Rick although suppose OP could get a cheap phono preamp as well for his budget.
Al ears said:
MUSICRAFT said:
Hi rchinn
All the best
Rick @ Musicraft
Hi Al ears
Yes, the Rost doesn't have a phono stage however the OP is already using a Firebottle valve phono stage which can be plugged into one the three analogue inputs on the Rost.
All the best
Rick @ Musicraft
DocG said:
insider9 said:
The choice of highly efficient design such as Class D will be ideal for hiding away as it won't cause heat issues.
I'd agree provided the unit goes in standby automatically. IME Hypex amps have substantial power consumption (and thus heat production) when idling. I'm not sure wether this goes for all class D amps (but that wouldn't surprise me).
EDIT: my Devialet runs pretty warm in idle too, but that could be the class A part of its ADH.
Interesting. My Devialet never gets overly warm. The hottest I've seen it at is about 45C. The internal heat sensors should be pretty accurate.
I would look at the Yamaha flagship amps a specially A-S 2100 / A-S 3000
both have an excellent phono stages and very good headphone stage also both amps have plenty of power to run any speaker as I am currently using Dali opticon 8s which are 4 ohm speakers .
build quality is outstanding and I would of thought would last you years also Yamaha do an A-S 801 which has more power then the A-S2100 which costs more then the A-S801 .
streaming I would use the Yamaha WXA-50 pre to Use for streaming as it takes no room up .
if it was me I would find the best pair of speakers I could find for that money and normally if funds are there I would be buying the amplifier at the same time .
because I've learned that buying a amplifier and then going home and trying it out on your own speakers that you own may give you a sound you do not like because 9/10 when you demo the amplifier in the shop they might not have your speakers to use as part of the demo so they will try better speakers that might cost more then what your own .
Well, 45°C is the kind of 'pretty warm' that I mean. Not uncomfortably hot. But not cold in idle either. And thus apparently consuming power.
(crippled English of mine...)
I own a Primare i32 and im very happy with it
Just recently added the NP30 Streamer too - really nice sounding completely like night & day compared to my Rega DAC
Quality made as well - the brushed fascias and machined knobs have a really nice feel
MUSICRAFT said:
Al ears said:
MUSICRAFT said:
Hi rchinn
All the best
Rick @ Musicraft
Hi Al ears
All the best
Rick @ Musicraft
You are correct Rick, I missed that..
I see your using a Naim Core - how are you finding it - general feedback seems to be very good.
regards tonky
