AMP for Dynaudio Emit M10
Problem witn the marantz and dynaudio Emit M10 is that the upper midrange,lower tweeter is just to soft, although better than the Nad C326BEE (valley in the frequecy responce of the emit m20 at 1000-3000hz if you angle the towards listening position, not seen any measurements of emit m10)
they sound a bit to unnaturally, not enough agression,oomph when you listen to some rock music,guitars,it's a bit to soft, just doesn't sound right
If you're sensitive to agressive sounding speakers and want a warm full bodied sound, emit m10 is the speaker to go for on a budget just above low budget ma bronze 2, q acoustics concept 20,dali zensor 3
You can also make the room more lively. Expose glass surfaces, leather, tiles, bare floors, glass coffee table etc.
