- Jun 25, 2015
- 9
- 0
- 0
no i havent. Read the reviewthewinelake. said:Have you auditioned/bought the speakers?
could you please give me some examples of amp that would be better?davedotco said:But buy something better if you can.
Dynaudio make good speakers but some of them only really come alive when driven well.
If you have not bought the speakers yet, consider the BM5a Active models with some sort of dac/preamp. Takes away all the matching issues and is a very refined, well developed system.
They can be bought for around £600-700 including Isoacoustic stands, seriously good.
gasolin said:Theres the new Marantz PM6006
Yoo'aab B. Eelaya said:could you please give me some examples of amp that would be better?davedotco said:But buy something better if you can.
ID. said:gasolin said:Theres the new Marantz PM6006
Yeah, that's probably not a whole lot more competent than the 6005 considering the power output and power supplies.
At least the M10 is nominally 6ohms, rather than the traditional Dynaudio 4 ohms, (M20 is 4 ohms).
the emits are not bright so I think you've bought the wrong Speaker but I will suggest the primare i22 or the rega elex-r for great pairing with the emitsDrDeepakJ said:Hello, am new to this forum . just bought an emit m10. Paired it with a marantz pm5005 . sound is on the warmer side . could someone plz suggest an amp that suits best with this speaker . by the way I like music to be on the brighter side . thanx
hi it will run the dynaudio's but yes will sound alot better with a more capable amp.i would suggest the new rega or the Cyrus one at about£600 or the primare i22 at £1000Yoo'aab B. Eelaya said:Hello, will marantz PM6005 work with Dynaudio Emit M10 speakers?
seemorebtts said:the emits are not bright so I think you've bought the wrong Speaker but I will suggest the primare i22 or the rega elex-r for great pairing with the emits
what's your budget.you do have some great speakers with great detail.DrDeepakJ said:I'll admit that i hadnt auditioned them n it was an impulsive purchase but still in whathifi's review , its mentioned as 'detailed sound'. Which I didn't find that detailed to my liking . so my question is whether there will significant increase in detail by upgrading to a higher amp . also could u plz suggest amps a little cheaper than the ones u mentioned
both are great amps.I did suggest the new rega bio in a resent post but the Cambridge might be more of what you are looking for with a brighter presentation.take your speakers to Richer sounds and have a demo.i like the rega better but it's about what you like.or I have another suggestion try one of these in your old amp cleareraudio /copper-line-alpha-plus-power-cable at £80DrDeepakJ said:For some I guess I will have to live with these due to budget issues . for amp I can arrange around 400-500 pounds . how will the Cambridge cxa60 or the new rega brio be? I will look for the used ones
