Question Aiwa APX-709BT/BK
Rockcandy
Where can I buy turntable belt for Aiwa APX-709BT/BK . Buying one is the only option. I tried Amazon universal belt but it was tool long, but I got my money back for this belt.
Thank You
Cricketbat70
460
305
1,270
I can see why you asked on here. I've done an internet search myself and can find replacement belts for loads of aiwa turntables but not this one.
You'd think for a current turntable a belt would be easy to find.
Sorry I can't help.
Gray
I've bought a few belts from CPC Farnell.
If you go on their website and enter 'Drive Belts' you'll see they've got quite a range.
They give all the dimensions - but knowing what yours should be is the key of course.
Flat belt widths and depths are straight forward enough - diameter, taking account of stretching, not so clear cut - but there are guides on calculating....even if yours is broken.
Of course, you'll be much better off doing what Al says above and getting a genuine replacement.
daytona600
Universal belts are not made tens of thousands of sizes
A/return to amazon/supplier
B/ or measure belt , and fit another turntable belt of the same size should cost £5/10
Flat or Round belt
0.6mm thickness x 5mm width (common size )
300/400mm long
DCarmi
If you don't have the original belt:
Get a bit of string and attach it as you would a belt. That way you get a guide to the length and diameter. Belts tend to come in a range of fixed sizes, so you should be able to locate a good match. Remember the belt needs to be fairly tight to grip the surfaces.
