Hi all,
I bought a Marantz M-CR603 in October 2013 (great deal!).
Initially, I did not have the Airplay upgrade, so I signed up and it was delivered.
It worked perfectly fine until I received an "upgrade notification" about 14 days ago.
I upgraded, and ever since, when I try to stream via Airplay, it connects briefly, sets the Volume to 50, then drops and the display shows "(list empty)".
Has anybody else experienced that, and (ideally) has a solution?
I contacted the Marantz support. They pointed out that no upgrade had been released for this model since 2012 (I believe that, but I only bought it recently, so it may not have been up-to-date), and they further seem to think that it's a problem with my set-up.
I have tried a number of steps as advised by Marantz:
- reset to factory default by power-cycling and pressing Volume up + Stop (says Factory Reset)
- reset the microprocessor by power cycling and pressing Volume up + Volume Down (says Initializing)
- replaced my D-Link (DIR-615) router with a Netgear model I had
- (temporarily) opened ports 3813, 443, 80, 8080, 3689 TCP, 554, 5353 UDP on my router (should not be necessary to open WAN ports for LAN communication)
- I have tried unplugging all other networked devices (particularly airplay ones)
- I have exchanged the network cable for one I'm sure is working without fault.
- I have tried both DHCP and static configuration.
Please note that:
- The iMac I am trying from and the Marantz are both directly plugged into the router (i.e. there is no wireless involved)
- streaming from my iPad wireless does also not work to the MCR603
- Playing music from my local music server works perfectly fine, so I think we can assume that the connection as such is ok.
- Airplay works fine on the two other Airplay devices in the house, which are a Apple TV and a Raspberry Pi (running Open Elec).
- Have a friend who own a Pioneer X-HM81-K, which he brought round this morning. We plugged it in to the same connection where the M-CR603 normally lives, and Airplay worked fine.
I noticed that every(!) time I power on the device (from standby) the display now says:
- M-CR603 UPGRADE
- Setup for starting...
- INTERNET RADIO
-- 1/4 Initialize...
-- 2/4 Connecting
-- 3/4 Checking Info
-- 4/4 Waiting Reply...
I did not see this behaviour before on a regular basis.
The scenario is always the same. The MCR603 shows as Airplay device. I then select it. It will play for about one second, then the connection drops. The MCR603 displays "(list empty)".
I have uploaded a video showing what happens, please PM me for the link.
I've copied in output from the Apple Console underneath. The message that stands out is the 61/0x3D ECONNREFUSED
I guess that the firmware upgrade went wrong, but Marantz does not believe me.
Below the excerpt from the Apple Console with the error messages.
10/01/2014 08:08:12.917 SystemUIServer[240]: 2014-01-10 08:08:12.916750 AM [AirPlayAVSys] Picking route 'MZ' (00:06:78:09:0A:F6)
10/01/2014 08:08:12.918 SystemUIServer[240]: 2014-01-10 08:08:12.917813 AM [AirPlayAVSys] Selecting endpoint 00:06:78:09:0A:F6, item 39 for (audio only)
10/01/2014 08:08:12.918 coreaudiod[159]: 2014-01-10 08:08:12.918456 AM [AirPlay] Selecting endpoint 00:06:78:09:0A:F6 "MZ" for A/V
10/01/2014 08:08:12.934 AirPlayUIAgent[16703]: 2014-01-10 08:08:12.933930 AM [AirPlayAVSys] AirPlay became the default audio device
10/01/2014 08:08:12.934 SystemUIServer[240]: 2014-01-10 08:08:12.934100 AM [AirPlayAVSys] AirPlay became the default audio device
10/01/2014 08:08:17.987 coreaudiod[159]: 2014-01-10 08:08:17.986678 AM [AirPlay] ### Audio send error: 61/0x3D ECONNREFUSED
10/01/2014 08:08:18.168 coreaudiod[159]: 2014-01-10 08:08:18.167752 AM [AirPlay] ### Endpoint "MZ" keep-alive error: -6753/0xFFFFE59F kConnectionErr
10/01/2014 08:08:18.168 coreaudiod[159]: 2014-01-10 08:08:18.167873 AM [AirPlay] ### Error with endpoint "MZ": -6753/0xFFFFE59F kConnectionErr
10/01/2014 08:08:18.168 coreaudiod[159]: 2014-01-10 08:08:18.167996 AM [BonjourBrowser] Reconfirming PTR for 000678090AF6@MZ._raop._tcp.local. on en0
10/01/2014 08:08:18.168 coreaudiod[159]: 2014-01-10 08:08:18.168247 AM [AirPlay] Quiescing endpoint 'MZ'
10/01/2014 08:08:18.168 SystemUIServer[240]: 2014-01-10 08:08:18.168472 AM [AirPlayAVSys] ### Quiesce AirPlay
10/01/2014 08:08:18.169 AirPlayUIAgent[16703]: 2014-01-10 08:08:18.168498 AM [AirPlayAVSys] ### Quiesce AirPlay
10/01/2014 08:08:18.176 coreaudiod[159]: 2014-01-10 08:08:18.175668 AM [AirPlay] ### Endpoint "MZ" auth-setup error: 200453/0x30F05 Not Enough Bandwidth
10/01/2014 08:08:18.176 coreaudiod[159]: 2014-01-10 08:08:18.175759 AM [AirPlay] ### MFi failed: 200453/0x30F05 Not Enough Bandwidth
10/01/2014 08:08:18.176 coreaudiod[159]: 2014-01-10 08:08:18.175854 AM [AirPlay] ### Endpoint "MZ" start failed: 200453/0x30F05 Not Enough Bandwidth
10/01/2014 08:08:18.176 coreaudiod[159]: 2014-01-10 08:08:18.175968 AM [AirPlay] Posted 'com.apple.AirTunes.endpointStartError' with 200453/0x30F05 Not Enough Bandwidth
10/01/2014 08:08:18.176 coreaudiod[159]: 2014-01-10 08:08:18.176101 AM [AirPlay] Posting kAudioDevicePropertyDataSourceInfoForID: item 39 error: 200453/0x30F05 Not Enough Bandwidth
10/01/2014 08:08:18.185 SystemUIServer[240]: 2014-01-10 08:08:18.185339 AM [AirPlayAVSys] AirPlay no longer the default audio device
10/01/2014 08:08:18.185 AirPlayUIAgent[16703]: 2014-01-10 08:08:18.185372 AM [AirPlayAVSys] AirPlay no longer the default audio device
10/01/2014 08:08:18.188 coreaudiod[159]: 2014-01-10 08:08:18.188108 AM [AirPlay] ### Write audio (2048 bytes) when client not fully started
I'd be very grateful if anybody has any hints / tips / tricks what to do. Airplay was the main feature that made me buy this Receiver, and without it it's lost half its use.
Many thanks in advance for the help!
Please note that:
- M-CR603 UPGRADE
- INTERNET RADIO
-- 2/4 Connecting
