Hi, thanks for the reply. That was going to be my 2nd question.......wether or not I could use a pre-amp (passive). As it is, and i've just done it as a test. It is really loud just coming though the cable then into the phones. It sounds more open and full........so if i can tame it down with a volume control without introducing too many extra electronics, hopefully i can get the original sound out of the CD player, without changing the music to much. I have been disapointed in the past with so called good headphone amps and just want the purest sound out of my CD player i can.........hopefully without damaging the CD player ??? I don't know enough about this sort of stuff.........but i've heard things like if it isn't buffered ? ....it might strain the output of the CD ??? I don't know.
So in theory i should be able to buy a passive pre amp ( or powered, but i'd prefere a simple passive ) and use the signal OUT on that in the way i discribed above, and have ajustable volume.............will different makes have different resistances / gains even in a passive, and poss make it quieter or louder ?
