- Aug 10, 2019
- 2,556
- 4
- 0
Evening all,
I've never had anything more than a 28" CRT TV and a DVD player but I've now decided to treat myself to a decent TV, receiver and speakers. I've just put this spec. together from reading magazines and looking at a few forums so (a) I have no idea whether all the items will complement each other and (b) I really am a bit clueless so bear with me.
I don't have Sky and at present have no plans to get it so I'll be using the TV for SD content as well as the PS3/XBOX360/WII/PS2/GC/DC.
The room is 3m 30 x 4m 20. The screen will be in the middle of the longest wall and the sofa will be opposite. On the right, as you're sitting in the sofa, is a large window with a low radiator under it. On the left there used to be french doors opening into the dining room but these have been removed so this is now open. The floor is laminate. Decor is white walls other than the wall that the sofa is in which is orange. Units in the room are white.
I've worked out rough cable runs for the speakers as follows:
Left rear - 12m. I will need to run the cable back behind the sofa, past the right rear speaker, under the window to the receiver.
Right rear - 4m
Left front - 4m
Right front - 2m
That makes 22m but cable runs need(?) to be the same length so that should actually be closer to 32m.
I'll be seated approx.2.5m/8ft away.
The following is my shortlist of items:
TV
- Pioneer PDP428XD - £1600 (+ stand)
- Panasoinc TH-42PZ700 - £1400
I was going LCD but have decided to go with plasma - mainly due to the SD content I'll be watching as I understand plasma is better for this than LCD.
SPEAKERS - good for surround but also audio.
- Q ACOUSTICS 1010i 5.1 - £500
- KEF KHT3005SE (gloss black) - £1000
- MORDAUNT SHORT ALUMNI 5.1 (White gloss) - £600
- TANNOY MERCURY F1 5.1 (apple wood / dark oak) - £700
- AUDIO PRO ALLROOM 5.1 (white gloss, blue, red, black, silver) - £700
The Alumni and Allrooms would go well with the room as you can get them in white gloss but colour is not the main deciding factor! The speakers also need to be good for music. I'm not too fussed about whether the front speakers are on the floor or stands. Rear may need to be wall mounted but I think I could also get away with floor/stands.
RECEIVER
ONKYO TX-SR875 £1000
The above choice is purely based on the What Hi-Fi recommendation.
I don't need a DVD player as I have the PS3 for the time being.
CABLES
SPEAKER CABLE
QED Silver Anniversary XT Speaker Cable?
PS3
QED HDMI?
XBOX 360
360 to 3 RCA or 5 RCA? Will I also need a separate optical cable?
WII
WII to 3 RCA or 5 RCA?
PS2
PS2 to 3 RCA or 5 RCA? Will I also need a separate optical cable?
GC
GC to 3 RCA?
DC
DC to S-video?
Is it also worth upgrading my aerial cable to something better?
Being a bit of a noob here but presumably the console cables will all go into the back of the Onkyo (where possible) and there will only be an HDMI cable to the TV from the Onkyo?
Some places are doing deals on the receiver and certain speaker packages so I may be able to save a bit of money there.
My budget is £4000 tops.
Apologies for the length of this post but thanks for taking the time to read it.
Cheers,
Chris
Right rear - 4m
Left front - 4m
Right front - 2m
TV
RECEIVER
CABLES
SPEAKER CABLE
PS3
QED HDMI?
XBOX 360
WII
PS2
GC
GC to 3 RCA?
DC
DC to S-video?
Cheers,
Chris
