No worries, we've all done it, Rob 🙂Oops repeating myself there.
Rob, have your attenuators arrived, if so have they had the desired effect?Oops repeating myself there.
Certainly is. NHS sent me out a screening appointment dated 30th November... I got it on the 30th December, the actual appt. was for 8th December! Seeing I had missed that appt. they sent another one out on the 12th December which arrived on the 31st December, that appt. was for the 23rd December! You couldn't make it up 😀Hi Doug, not still not arrived. Post seems to be crawling at the moment.
Ok they've arrived. Just after I called Analogue Seduction for a tracking reference. First impressions are a bit mixed. At the moment, I'm getting the impression that they definitely do their job of attenuating volume but I'm not sure that they aren't strangling the sound a bit. I've got a crude db app on my phone so I suppose a pretty basic test would be to try and compare the sound at the same spl. I'll tell you how I get on.Certainly is. NHS sent me out a screening appointment dated 30th November... I got it on the 30th December, the actual appt. was for 8th December! Seeing I had missed that appt. they sent another one out on the 12th December which arrived on the 31st December, that appt. was for the 23rd December! You couldn't make it up 😀
👍 I never found them anything other than completely transparent. The resistors used in these are selectively matched pairs.Ok they've arrived. Just after I called Analogue Seduction for a tracking reference. First impressions are a bit mixed. At the moment, I'm getting the impression that they definitely do their job of attenuating volume but I'm not sure that they aren't strangling the sound a bit. I've got a crude db app on my phone so I suppose a pretty basic test would be to try and compare the sound at the same spl. I'll tell you how I get on.
I've read about the benefits of adding a sub for music (not really interested in home theatre tbh) but up until recently had been skeptical. However, I know they can be small and discreet and still make quite a difference. What are people's thoughts bearing in mind I have an amp with no sub out (but it does have 2 pairs of speaker binding posts)? Thinking about something like Rel t5i (budget £350 ish).
Could be brain/eye tricks. I did try cheaper versions before the Rothwell's which definitely changed the sound, hopefully Rothwell quality is still as good as it was.I'm sure you're right, it's probably a psychosomatic thing. When you move what you would normally hear at a certain point on the volume dial it does strange things to your brain. I suppose it would pretty easy to do a blind test with this using a blindfold and another person. I might just do that for the fun of it.😉
No, never, Rob. I've had floostanders and whilst I may miss the visceral chest thumping bass I find my current speakers play better with my room. Not something I would completely rule out in the future, but room treatment may be required.I notice by the way you're not a subwoofer man. Have you ever had a sub in your system?
I do have a sub with my cheap Pannie surround sound.
I'd suggest that the frequency of a kickdrum to feel it in your chest is as much due to sub 40Hz too. You need a big driver to generate those kinds of SPL at those frequencies, I've only ever felt it at live gigs. The heart beat on the opening track of Breathe on dark side is a good test. I tried out my JL sub using it, and disconnecting the main speakers, there wasn't much of a difference tbh, most 9f the volume was being provided by the sub, not the main speaker. Bottom E on a bass guitar is 42Hz, not many home audio systems can replicate the punch of the bottom end of a bass that you'd feel stood in front of a 500W Ampeg!up to 40hz – really deep bass. 40–60hz – deep and punchy. 60–80hz – low punch. 80–120hz – high punch.
Getting a 'kick' from bass or a 'chest thumping bass' is probably more a quest into the mid and upper bass frequencies of a loudspeaker woofer, and less in a sub. If an example of a song that should deliver what's subjectively described can be given, it might make things more clear to also deliver in that region.
There's no such amp as this. Did you mean 800ne?Denon PMA-700ne
You said you had Rel before and it was a nightmare to set up. How was it a nightmare and did you give up?I'd suggest that the frequency of a kickdrum to feel it in your chest is as much due to sub 40Hz too. You need a big driver to generate those kinds of SPL at those frequencies, I've only ever felt it at live gigs. The heart beat on the opening track of Breathe on dark side is a good test. I tried out my JL sub using it, and disconnecting the main speakers, there wasn't much of a difference tbh, most 9f the volume was being provided by the sub, not the main speaker. Bottom E on a bass guitar is 42Hz, not many home audio systems can replicate the punch of the bottom end of a bass that you'd feel stood in front of a 500W Ampeg!
Mine are far enough away not to be annoyed 🙂by the way, about this whole experience issue.. loud volumes play a role too.
don't you guys have neighbors nearby? 🙂
Bass does not necessarily mean louder volumes.....
No, typo, its a 600ne. Post edited, thanks for pointing it out.There's no such amp as this. Did you mean 800ne?
Search for subwoofer crawl. It will explain the process of setting up a sub so that it in phase with the main speakers, my mistake and poor memory, it was a JL Acoustics sub I had, which had an infinitely variable phase adjustment. Then setting up crossover and volume, all of which I was doing by ear. As soon as you move anything, you've got to repeat the process. I didn't give up, because I'd invested so much money in the system, and when it was done it sounded awesome.You said you had Rel before and it was a nightmare to set up. How was it a nightmare and did you give up?
Yes, but not so close they can hear it. You might do walking past in the street though.by the way, about this whole experience issue.. loud volumes play a role too.
I love my 800ne. Which Elac speakers do you have? I think Elac speakers are great.Search for subwoofer crawl. It will explain the process of setting up a sub so that it in phase with the main speakers, my mistake and poor memory, it was a JL Acoustics sub I had, which had an infinitely variable phase adjustment. Then setting up crossover and volume, all of which I was doing by ear. As soon as you move anything, you've got to repeat the process. I didn't give up, because I'd invested so much money in the system, and when it was done it sounded awesome.
That said, now that I've rearranged my room, it's quite different. The Elacs go pretty deep anyway and there's a noticeable boost around 45Hz from the room. The wharfedale sub seems to work OK at its lowest crossover setting, and about 1/3 volume, and the phase switch set to 0°. I'm really impressed with the system, it seems to continue to surprise me how big it sounds, whereas in the past I've had more expensive systems that were slightly underwhelming. The Elacs are well known, but this entry level Denon punches well above its weight.
