Electro
Victor Fabian said:Thanks to all for replying,
The speakers are mounted, each one, in a dedicated foot, just 40 cm from walls. I can't do better with that. The living room does not me allowe a better configuration, although I have separated them from the walls one meter and still the sound is amalgamed.
When I listen to a well recorded CD (Patricia Barber or other jazz music) sound is good but when I go for my rock records (Cure, U2, ...) and there are plenty of instruments the sound is like an amalgame, everything is mixed, there is no separation of instrument. I do not think the problem are all these albums (I miss high frecuencies also ). I have taken some of them to an average shop of music and played them in a budget dvd player/ampli with speakers less expensive than mine and the sound was clear and I could recognized the strings from one side, the drums too, keyboards, etc...
I know tha V2.0 UP is no the best amp of the world, I jsut thought that an amp giving more current and able to "move" my speakers at low volume could be that one. Yes, I lke music sounds good at low volume as I spend most of my nights awake while I work at home. I think my speakers have a medium/high sensibility (89db) and should deliver a good sound at low volumes. That is why I thoung the problem was the ampli. Of course I know very well that a cheap B&W will sound better with my marantz becase they match very well but , as I said, I'll be difficult to sell these speakers and I think they are good, juste need the right amp.
It's a shame I can not post in here a picture of my HIFI chain, I have a pic in my computer but I do not know how to doit.
Many thanks again
victor
To post pictures you will need to upload your pictures to a free hosting site like photobucket .
http://s1153.photobucket.com/
You can then copy a dirct link from photobucket and use the image tool at the top of the comment box to insert the URL and the picture will appear in your post.
The Abrahamsen V2.0UP has very high current delivery and should control you speakers very well separating out the strands and textures of the music and presenting them in a very natural way similar to how live music sounds.
I would definitely recommend one. *smile*
