It's a long story, but not to put too fine a point on it, one of the two Audiolab 8000S amps I sold on eBay last year is back with me. I'm talking of the classic, pre-TAG model here.
The problem? The connections for inputs are actually falling apart - disintegrating - it's as if the plastic molding is suffering the equivalent of metal fatigue. I opened up the unit, having looked at the inputs from the outside, noticing a couple had gaping holes where the red or white plastic should be, and found various pieces rattling round inside, and the others showing varying signs of cracking and/or breaking away. This includes input connections I never even used. Based on my communication with the chap who bought the amp from me, I doubt he has treated it badly during the last 7 months. I genuinely believe the plastic has begun to 'perish' after almost 20yrs.
The question is: is it feasible and, indeed, economical to get replacements for the input pieces (and get them fitted - ouch!?) or are we talking consigning this otherwise perfectly good amp to the skip?
Has anyone else had similar problems? If I found a cheap modern version of the amp, is it possible to use it for spares?
Or do I just give the chap a (limited) refund and cut my losses? Ideas anyone?
