A good starter system for £700 if there is!!
Hi am looking for a home cinema but havent got loads of money to spend on it,either 5.1 or a soundbar for the wife.
I got £700 saved up now,just wondering if shoul keep savin or there somethin out there now to keep me happy,would i need cable with it to??
Hope you can help
Sorry forgot!!
Tv sony kdl-40w5500
blu-ray panasonic dmp-bd35
Virgin +
X-box & a wii
Clare Newsome
1,657
I'd go with a Sony receiver (the handset will control your TV, too) - the STR-DH800 (can be had for £250)
And a set of these Q Acoustics speakers, which can be had for @£399
Bingo - superb-sounding home cinema system.
If you wanted smaller speakers, these @£300 Jamos are the business (but the Q Acoustics package will give you more bang for buck).
Don't forget to budget for cables/stands/brackets as needed!
If you can then go for the full 5.1 system over the soundbar. Some people don't like huge speakers cluttering up their living room. Personally I love em. Difference in sound is huge. But if you do there are some decent style packages out there
Try your local richer sounds store. All you need is a 5.1 speaker system, an AV amp and lots of cables to connect it all together.
RS are pretty good with prices, especially if you are buying more than one item. Most if not all their stores have demo rooms so can hear what you will be buying. They may throw the cables in FOC.
For example you can get the KEF KHT1005.2 speaker package and the Sony STRDG820 Amp for £400 & £230 respectively. Add on say another 15% for cables (£94) and thats a bit over your £700 budget but as i say I've always found RS to be pretty good with discounts.
If you can get away with larger speakers Superfi are also doing the Q Acoustics 1010i 5.1 speaker system for £350, so thats another option.
Whatever people advise, always go and listen to it first before parting with your hard-earned. Good luck and hapy hunting.
scousejay:
Hi am looking for a ............. soundbar for the wife.
Is that a good swap
');" title="Big Smile -
Sorry just my humour - couldn't resist
Big Aura
522
10
18,895
I wouldn't swap my wife for a pair of Nautilus.
A 5.1 Nautilus, tho........
PS - entirely the wrong sub-forum, but was a bit surprised to see they didn't feature in the ultimate guide to high-end....
I got the sony and jamo speakers,am well pleased with them to,films are so much more now got them
So thanks for advice
Jay
Look at my specs below
Amp 250.00 delivered
9.1/ 99.95
alumni 130.00 rears
Amazing
under 500.00
