Hello all,
I have recently purcahsed the Wharfedale Diamond 9.1 speaker system along with Yamaha RXV379 amp (configured for 8 Oshm speakers). The Wharfedale speakers nominal impedance is 6 Ohms with 100W power handling.
The Users manual for the amp states that the impedance should be changed if using a 6 or 4 Ohm speakers, but the setting is only available to US and Canada devices. When I connected my 6 Ohm speakers, they produce a strage distored sound. The bass is intermitent, with it often not playing, leaving just the tweeter, and the sound overall is very bad. I have added a link to a short video below to demonstrate.
I have connected a set of 8 Ohm speakers which appear to be working perfectly.
Is this a problem of the speakers (are they broken) or is impedance mis-match causing this loud distortion and bass drop-out. Do I need to send these back to the seller?
Video: https://goo.gl/photos/RCcCC2ZK8Dq7LKLw6
I will be very grateful for your feedback.
