I've took the plunge and got a 46G20 last Thursday. Last night was the first night I got to have a good play around with. What a piece of POO. To say I'm disappointed is an understatement.
The good bits are the black levels they are as good as everyone says. Not that much better than the 46C750 I must admit but they were a lot more solid on images with large areas of black and no floating blacks. So far so good. Watching The Deep on BBC HD had really bad colour banding all the way through. On faces around the cheeks and spot light walls. The exterior scenes were worse still. It's as if there are not enough colours available to make up the image. I switched over to The Bourne Identity on ITV HD still the same colour banding. I put on a couple of bds. The Dark Knight, Watchmen and Toy Story 2. These were fine with regards banding but had other issues. I also watch some of Smallville recorded in sd of Sky+ through rgb scart. The colour banding was really bad. The second issue is motion everything changes hue when it moves or there is anything more than a slow pan. It also creates a blur. This is worse the better the source. The Batpod sequence in DK was just unwatchable. Just a mass of green tinted blur. I ended having to turn the tv off due to headache from eye strain.
The settings are THX mode, contrast down 3 clicks, all processing off, sharpness 0 and no direct lighting on the screen. Power through a tacima with ony the tv and Sky+ box in. I also tried a Chord Superscreen cable.
Can anyone shed any light? At the moment I'm going to give until Wednesday the it's going back. Looks like my AV days are over after 17 years.
