I am new to home cinema, but am about to buy a house which has "tremendous opportunity for modernisation". So, whilst the floorboards are up to install central heating, I thought I might as well go all out and install a 5.1 system.
So, with that in mind went with my brother to his local audo shop, and saw their Yahama RX-Vs, which all look pretty swish. They have the V1700 at £550 (ex-display) which is probably good enough for me as I am no expert in these things and will be moving from a CRT TV anyway...
I will be pairing it with a 37" TV and probably the Q-AV 5.1 system, with a PS3 and either Sky+ or BT Vision.
I really only up to £600 to spend on the amp as I have to buy the rest of the kit, as well as a bathroom, central heating system, kitchen...
Would the V1700 be a good buy (the salesman said I would have to run the sound thru an optical cable from the PS3 as the HDMI inputs won't be able to split the sound?) or as it is a 2006 model is it really now obsolete? The other RX-Vs all look good, but a lot more expensive.
The relatively button-less front (thanks to the drop down panel cover) will please my girlfriend who's keen to have it look good when not turned on - she's a little like Monica in that repect...
Or should I follow the masses and get an Onkyo?
Any help or recommondations would be appreciated.
